PeaKing - 12/15/2020 10:26
What do you have now? Did it supply you with acceptable water in the past? How much iron do you have? What is the hardness of your water? If what you have worked previously just replace it. If you are able to install it your self all components you would need are readily available online at reasonable prices. Probably would need an iron filter a water softener and an R.O. should be able to get all 3 for $1500 or less online.
Good thought. Rust filter a must |
