Search Forums | Classifieds (145) | Skins | Language
FarmersEdge VS Agdna?
Eric from Canada
Posted 11/17/2020 20:53 (#8612192 - in reply to #8608547)
Subject: RE: FarmersEdge VS Agdna?
Quebec, Canada
What year/model is your Case combine? If it is relatively recent (2009 or newer) it is probably compatible with FieldView. Our FieldView Drive plugs into the combine’s diagnostic port to collect the GPS, yield and moisture information from the combine and sends it to the FieldView app on an iPad. There are adapter cables available for the Trimble monitors so mixed fleets are not a problem for collecting planting/spraying/tillage/harvest data. The annual fee for the software is $150 CAD (1 year free if you sign up for BayerValue), then you need a FieldViewDrive ($329 CAD), some adapter cables and an iPad.
My email is in my profile if you would like more information, or if you would like a quote for what FieldView would cost you (it will be much cheaper than $5/ac)
FieldView is good at comparing yields across fields and/or varieties, but does not do any COP analysis. There is a program called Harvest Profit that does a good job at that and you can choose to link your accounts which lets Harvest Profit get your application and harvest info to calculate profit and loss field by field.
