Search Forums | Classifieds (139) | Skins | Language
John Deere technicians, I need your help!! Air filter restricted code
Mitchco
Posted 11/1/2020 11:13 (#8579756 - in reply to #8579260)
Subject: RE: John Deere technicians, I need your help!! Air filter restricted code
SW OH
Check all the air ducts leading up to the air filter including the pre cleaner. Komatsu 228 track hoes are notorious for showing a code and new filters and sensor won't fix the problem. The inlet on the air cleaner is covered by a piece of window screen. The drip tube from the AC evaporator drips below it. It sucks there mostiure in through the screen. When working in dusty conditions it will plug the inlet to the air cleaner.
Mitchco
