west central Iowa | Basically Trimble will not work with Ag Leader. There are certain exceptions, but these exceptions don’t allow you to use a repeater. This is where you consult a very good Ag Leader dealer and have him guide you through the process.
Once you have a common base point for the farm, do a survey point. This will find its exact point on the earth. Handy if you need to change or update base. You can re enter this point location and past guidance lines and boundaries should line up for future use. | |
