Hi all, Want to invite you to test new analytics modules in GeoPard precisionAg system. We now can analyze yield, soil (sampling, EC), satellite, and topography (based on lidar data for corn/cotton belts). You can quickly create zones that are perfect for your fields. Some examples from our clients: - OM + Slope + Vegetation for the last 15 years - EC + elevation + last 3 years vegetation - Vegetation stability map + slope map + Moisture layer - Averaged of yield files with setting of custom weights to each year (for example latest years can have more weight in the final map) For each of the data layers, you can provide your weight in the equation. These maps can be used for zonal soil sampling, VR planting, N application. For one field we provide this service for free, then cost depends on modules, each module is $0.25/ac/year without limitation in the number of maps created. The solution is totally in the cloud and we have a mobile app with offline map capabilities. Thank you, Dmitry
Edited by GeoPardAg 10/19/2020 06:22
(GeoPard multi-layer-map-example (full).jpeg)
Attachments ---------------- GeoPard multi-layer-map-example (full).jpeg (66KB - 274 downloads)
