Auto slack adjuster
hillfarmer
Posted 10/18/2020 03:03 (#8551052 - in reply to #8550964)
Subject: RE: Auto slack adjuster
they need to have an inch of stroke so a turn and a half would give them way to much
should be like 1/3 to a 1/2 to get the stroke
running them applied should not have tightened them up
they were a bit loose, if you could drive away, unless you have LOTs of HP
If you back up a bit before driving ahead, and watch for the "roll"
it helps to check for brakes that are hung up
