NE South Dakota Clark, SD | In theory, you would take the data from the Ag Leader display and read it into SMS. Then export the lines as shape files. Read into JD Ops Center and export setup file to 4640. However last I heard, Ops Center could not read in line files. Keep on JD about this.
On a 2600 or 2630, you could create a .bmp of the tile layout and then read that into APEX, and then export as a background image. Apparently JD did not feel that was very important to enough people and removed that functionality from the new displays. That is the only reason I own APEX. Keep your 2600 and 2630 as long as possible if this feature has value to you. |
