| Looking to set up some nozzles off the back of our mounted planter. Currently running InCommand 1200 for planter monitoring and SureDrives. Would like to use the 1200 as well for liquid control. The plan is to hopefully add a front mount tank and put our pre emerge down while planting.
Is this possible? If I’m already set up for spraying with the InCommand 1200 using a 3pt sprayer, what exactly would I need to do to still be able to use my planter monitoring system as well as liquid control?
Would like to add section control as well for when we are planting odd rows. Would there be a way to tie in the spray sections to the sections set up for the Suredrives? We run 8 row planter so each row can manually be shut off using the switch box that AgLeader makes. Would be efficient to have the spray and suredrive cut off using the same switch.
Edited by piratepride2 10/15/2020 01:36
