NE Kent County, MI | Eric from Canada - 10/16/2020 09:31
When the 20/20 is in YieldSense mode it will only send over the yield layers. Try switching the 20/20 over to SeedSense mode to sync the planting maps (obviously don’t do this while you are actively harvesting, then you would lose the harvest data). Depending on how much data is on the 20/20 it might take a while for all the planting maps to get onto the iPad. I did something like that with a client last year, had an adapter to plug his 20/20 monitor into the wall socket and we left his iPad plugged into his 20/20 overnight (he had 5 years of planting data to send over).
Ok I will try this. Thank you. Side note.. my iPad isn’t charging off my 20/20, I’m having to pull iPad at night to charge at home. |
