Search Forums | Classifieds (57) | Skins | Language
Fully loaded S670
   Forums List -> Where Can I find?????Message format
Doren
Posted 10/13/2020 14:18 (#8544225 - in reply to #8544189)
Subject: RE: Fully loaded S670
We are close except for power cast 785-443-1669 David
https://americanimplement.com/used-equipment/2017-john-deere-s670-85...
2017 JD S670 STS, Contour Master, Pro Drive Transmission with
HarvestSmart, Command Touch Multi Speed Drive, Premium Cab,
AutoTrac Activations, Enhanced Air Susp Seat, Harvest Monitor,
2630 on Arm Rest, Small Wire, Gen Purpose Shoe, Custom Cutter
Ext Wear Pkg, Extended Wear Grain Handling, ICA, 7.9M Unload
Auger, Power Folding Grain Tank Cover, Man Adj Vane Tailboard,
Chopper, 110v Coolant Heater, LED Lights & Extremity, 520/85R42
Michelin Duals, 750/65R26 Rear Tires, (Recon of $13,495 @ 866
Sep Hrs as of 03/09/20 ) PGC @ 1159 Hrs - 02/17/20
1H0S670SAH0795230 Good 1159 Eng
866 Sep
