Raven unlocks
Amc4life
Posted 10/12/2020 08:38 (#8542078 - in reply to #8538253)
Subject: RE: Raven unlocks
Butterfield, MN
It also depends on which way you want to do the rate and section control. If it's through ISO, you will likely need to order the ISO UT and Task Controller unlocks. However, if you wanted to hook up an SCS console like a 450 and add AccuBoom to that, those require no unlocks to get the same functionality.
