Case IH 8240 moisture sensor issue
dgramenz
Posted 10/5/2020 22:51 (#8532120)
Subject: Case IH 8240 moisture sensor issue
SW Illinois
One of our 8240’s is having an issue with the moisture sensor in beans. In corn, it works fine. But in beans, it will read at first when the separator is started and the sensor fills up. Then it locks on that reading until the next time the separator is shut down. Then it cleans out and we start the process over the next time the separator is started. From what I’ve read, it sounds like the proximity switch needs to be adjusted, but I’ve never seen directions on how to set it correctly. Any insight? Thanks.
