NW Iowa | You need to remember you can’t hang over the ditch with that 12’ wheel width and there can be some nasty holes or low cement abutments in the shoulder. Otherwise the law probably will not bother you. Going around sharp curves with that long of a wheel base and wide wing span can be dangerous if you meet a car with an inattentive driver behind the wheel. Chose your route carefully with that in mind and you will do OK. | |
