S.E. Washington | I know when I replaced the I PTO drive shaft on mine the first shaft was for the wrong serial number range. Everything fit and ran fine, but it had an awful gear whine. Put the correct one in, and it was as quiet as can be. The shape of the teeth were just ever so slightly different. Possibly there are miss matched gears in the pto? Hopefully a more experienced IH guy could tell you more. | |
