Schlegel Farms, Hagerstown Indiana | Sundance - 9/29/2020 09:29
Side zip with composite toe is my daily wear. Quick and easy on and off. Combine unloading vertical auger lower casting fell from it's mounting position on my toe and did nothing but leave red paint on the boot.
https://reebokwork.com/rapid-response-rb-rb8894/
So you just slip them on and then zip them up and that's it?
No laces to fool with everyday?
And it sounds like they are a real workboot.
That sounds like just what I need.
I'm not sure what changed in my feet as I got older, but the last pair of slip-ons I had got hard to get on. I've always had a high arch, but something changed because I'd worn slip on boots for over 50 years.
I knew I was in trouble when the old worn out pair got hard to put on....and sure enough....there was not a new slip on pair in the store I could get on.
Does the zipper hold up pretty well? I have a couple pair of dress boots with zippers and it always seems the zipper is the first thing to go. |
