Upstate New York | I think video/camera over lte data will take up alot of your allotted cell phone data plan., might get expensive if you are going with some type of cellphone carrier. I don't think you really need a 'special' router, but I'm not sure what you are gaining with the router in your case...Can you just move the phone closer to the camera to connect it to wifi?
Side Note: I'm going to try something similar. I'm going to purchase this hot spot and try and gauge how much data it uses, throw it in a shack next with 110v and use that as the internet and try the steps gms bin switch system to see if I can remote turn on the bin fans...and use a wifi camera/solar panel) to try and monitor the bin remotely.
If you were looking for a special router, cradlepoint makes some routers that are designed to be used with cell phone data and hardware as the source. Something like this one.
Let me know if any of this helps! |
