Posted 9/28/2020 19:02 (#8520154 - in reply to #8520026) Subject: RE: Bending 3/16 sheet without a brake
Ohio
That is a great tip ! I like it because it will enable the two pieces to butt together for welding . Tack lightly then cut thru the small uncut pieces of the bend and remove the bent strip . Anytime you later two pieces and weld , that is a rust enabling fix .
