Posted 9/28/2020 17:17 (#8519982 - in reply to #8519928) Subject: RE: Ih 30 1020 header likes to break sickle
Stoddard Co. SEMO
Dwhgsxr - 9/28/2020 16:44
I was told if the ( A frame ) the bracket that the wobble box bolts . If the bearings which are at the back of the head are wore out the wobble box will be misaligned and therefore will break things . There is a grease zert for them but they still wear out. ?
Absolutely the life of a 1020 head. Check the A frame bushings. The whole head, is as only good as those bushings.
