| Ok, mine is a 675D so we’re on the same page. The disconnect is on the right side on the tractor ahead of the rear wheel, under the cab on the side of the frame. It’s a black box with 3 or 4 wires going to it I can’t remeber. If you think that’s bad then take the wires off, clean the ends and bolt all the wires together. That’s what I had to do for mine.
When you press the red disconnect button under the right side panel behind your Right foot as you sit in the seat, does it click? | |
