| Got it fixed. of all things the egr exhaust valve recirculating valve was plugged in and also sensor that shows temp when regenerating . So engine was getting erratic temp readings causing turbo actuator to constantly open and close and that made engine run erratic. John Deere dealer plugged them in after changing a injector for us and never acted up for 3 years till now!!!! Couple thousand $ fix to find something this simple. Changed turbo plus Dealer bill for spending hours to TRY to find it but couldn't. So for everybody out there if you have a deleted engine and your dealer needs to work on it make sure emission stuff is all right after they are done!!!! I am sure they did not do it on purpose!! | |
