North Dakota | Voltage on the sensor needs to be between .25 and 4.75 volts or the monitor will give a fault. To check and adjust the voltage go the the diagnostic page and the settings tab. Find the header height in the to box and in the bottom box choose the left header sensor, or when the fault comes on choose the diag button. Set the voltage on the sensor to .75-1.0 volts when the header is up. Level the head and do a header calibration. | |
