Southwest MN | Was hauling manure with our 4230 today suddenly started squealing. Sounds like hydraulic pump. Took coupler off appears splines on the shaft coming out of the hydraulic pump were worn enough to finally let go. Question is can that shaft be replaced in the frame or only option to pull the pump. Tractor has enough hours and not used much. Not real crazy about putting a pump in it unless I have to. Thanks | |
