NW KS | I have a set of drills that has a hydraulic lock valve to keep the cylinders from moving without having pressure on the other line. The lock valve makes the cylinders shutter when they retract. The valve has an adjustment on it that is supposed to solve this problem but it hasn't seemed to help. I would like to keep something on the drills to keep the cylinders from settling when in the transport position but not sure what else I could use. | |
