Posted 9/27/2020 09:23 (#8517336) Subject: SDman I could use your help on a quadtrac.
NE SD
I posted over in precision talk but not getting much help. Have tier 4a 500 quad and the guidance isn't working. Tracked it down to an issue with no signal from quad encoder. Blinkers do not work whatsoever. I checked what I believe to be both fuses for the blinker assembly and they appear good. Have you seen these fail before?
