Maryland | I have a gsi CF -10hp with LP heater on a 30 ft bin, 6 wide rings. The heater is high flame or off type. my problem is the transition is so hot on one side you cant hold your hand on it the other side just warm. Ive tried to turn the burner and it doesnt help. The stands are metal with holes, the load out is at 10 oclock and the heater is at 6 oclock. Standing behind the fan looking at the bin the right side of the transition gets the hottest. just to the right of the transition the the bottom ring below the floor gets very hot also. i never run it much above 100-105. any thought would be appreciated. | |
