East Central, Nebraska | i just pulled an ez guide 500 and ezboom out of a sprayer a month ago to put agleader in. i traded the 500 off but have the ezboom if your looking for one. you can do this a couple ways. you can get rid of the 460 and use only the 500 but that would require a liquid unlock i believe. or the other way and the way that my sprayer was setup is you keep the 460 in the cab and the raven cable that plugs into it plugs into the ezboom and then you plug the ezboom into the 460. this will give you section control with the ezguide 500 and not require any unlocks in the 500. | |
