Posted 9/17/2020 07:24 (#8500253 - in reply to #8500035) Subject: RE: J&M cart auger cylinder issue
I've seen debris ( degrading o-ring material) pack against the tip on the return hose.. I have a field cultivator that did it when trying to lift on the end rows...
Both lines would jump with pressure, so I knew oil was making a full circle, it just couldn't make it past the tip.
