Quebec, Canada | It must be possible because FieldView has an adapter cable for 2630 monitors with serial gps. Looking at the setup guide for our cable (CC1081K) it seems like the gps signal can either go through COM port 1 or 2 and that the signal goes through the main cable at the back of the monitor. I’m guessing that there might be some extra pins to push into the main connector which would add the wires for COM ports 1 & 2. I don’t have any wiring diagrams, you’ll want to reach out to your JD tech to ask how that works. | |
