Search Forums | Classifieds (47) | Skins | Language
Best way to make a Circle Prescription in JD Operations
bucsma
Posted 9/12/2020 14:04 (#8491251)
Subject: Best way to make a Circle Prescription in JD Operations
Southern MO
I am needing a way to identify the center pivot circle on the tractor's 4600 monitor screen without losing my exterior boundary.
Note:: the end gun makes the circle go outside of the exterior boundary on all 4 sides.
I would like to make a prescription so the tractor hitch would raise as is goes out of the circle. I'm using Agrian to create a tillage circle prescription but I can't get the tractor to accept it. 8270R with 4600 display. Non ISO implement(is this the problem). Do I need a rate controller?
I can raise and lower the hitch manually if necessary but so far the only way I can get a circle boundary is to lose my exterior square boundary. Interior boundary does not work because it goes outside of the exterior boundary on the flat sides of the field.
Thanks
