NW Central Ohio | They sell a product up here called "Pro-Ton" that is a mixture of brown mid rib sorghum sudan...field peas...and soybeans. They push it as a replacement for corn silage because it can actually be planted after wheat and still yield in the 10-13 ton of silage range. I has very good numbers for feed usage too...I think you can find them in the online Rupp Seed catalog. If not you can call them. Soybeans ensile very well apparently. | |
