western iowa,by Denison | not really-a tub grinder with 3/4 to 1 inch screen works good-then you could switch it to 4-7 inch screens and grinding bedding-then just dump it in with loader.
We use a bale king with stainless bottom to blow cornstalks in are buildings but only do about 1,000 bales a year of cornstalks-we have a used 1,000 haybuster set up for grinding corn-it will grind pretty quick-when in a push we will run the 1130 haybuster in wet corn-its a beast of a machine and will grind 100 bushel a minute-makes the 8520 jd bark
the bale king cost $8800 used and found the 1,000 haybuster for around $6,000 with all the work Adam did
can run both those machines with 100hp tractor-the warmed up 4430 will spew it out though if in a hurry | |
