Posted 9/7/2020 18:29 (#8481555 - in reply to #8480891) Subject: RE: GPS signal from EZ Guide 500 to Ag Leader Insight
East Central, Nebraska
where the rtk correction comes from makes no difference. as stated in the post above it is possible and not hard to do. i would recommend just buying the cable you need to do so. agleader display cable should already have a 9 pin serial adaptor on it. as stated above you will need to turn on the nmea strings and rates that the insight likes. biggest one is gga and i would run 5-10 hz.
