Posted 9/24/2020 11:53 (#8512934 - in reply to #8478947) Subject: RE: Raven CR-12 GPS
Hello, I am a Raven dealer but have never had my hands on a CR 12, I would think that yes the Steering will be much better than the Cruizer II although it depends on how you describe "use it with accuboom", if you are just using an accuboom node hooked to section valves through a CAN connection to the cruizer then that should work I am told.
