Kansas | Has anyone ran across the active memory fault on a C1000 armrest control center screen in a Challenger or Massey rubber tire tractor? I am trying to set it up for the operator to engage his Trimble system through the headland button function and when i try to set it up i get the active memory fault. I've tried to use a usb and sd card in the C1000 and still haven't had any luck. Does it need to be in a certain format or have a certain file on it? There doesn't seem to be much information out there and the dealer is unsure as well. Thanks | |
