Posted 9/15/2020 06:43 (#8496425 - in reply to #8458922) Subject: RE: UHarvest Pro
Watertown S.D.
Does take someone that is a little tech savvy to setup! One thing I don’t like, is if you fill a truck but it’s a couple thousand pounds under your preset max weight and you dump that truck, the next time you select that truck it still things it needs those couple thousand pounds!
