Posted 8/13/2020 22:16 (#8433907 - in reply to #8422578) Subject: RE: Fine tuning JD Guidance
West KY
I think you probably set it up backwards. Should have used passive guidance on the first pass and active on the following passes. Should have worked about perfect. I’ve set up lots of systems this way and needed very little fine tuning.
