Posted 8/7/2020 18:40 (#8421450 - in reply to #8421430) Subject: RE: Hooking up well pump?
WY, OK
All you need is a 1/3hp control box and a generator to power it, turn it on to run the pump and off to not. Can run black PVC as a riser and adapt an elbow at the top to your hose. Can also hang the pump with the pipe or attach a rope if you are really worried.
