Posted 8/7/2020 16:10 (#8421222 - in reply to #8421153) Subject: RE: Portable moisture tester needed
Croswell, Michigan
I’ve been satisfied with my Mini GAC. I have a small rubber feed pan that I set it in in the office or pickup to catch grain when you level it. In the field I just climb down and do it on the ground. Plus I don’t think the vibration of the machine helps the accuracy.
