NE CO | Disengage/disable same thing what I'm referencing, turning it to off will kick it off, then flip it right back to ON and it's ready to go again, just hit resume when you turn and are ready to go again. You can go through the whole process in about two seconds.
Disengage AutoTrac ™ System
AutoTrac™ system is disengaged by:
Turning steering wheel.
Slowing to speeds less than 0.5 km/h (0.3 mph).
Toggling the Steer On-Off button until Steer Off is displayed in Guidance View tab or Guidance Application.
Operator being out of seat for more than 7 seconds if using seat switch, or no activity is detected by operator presence monitor for 7 minutes.
When AutoTrac™ is active, the operator can turn the steering wheel to disengage AutoTrac™ and steer manually.
Alternatively, the operator can toggle the road and resume switch to OFF position to disengage AutoTrac™. This drops AutoTrac™ to 1/4 status pie and starts a 30 second timer:
If the switch is turned ON before the 30 second timer expires, AutoTrac™ is enabled at 3/4 status pie. Press the resume switch to reactivate AutoTrac™.
If the switch is turned ON after the 30 second timer expires, AutoTrac™ is configured at 2/4 status pie. AutoTrac™ must be re-enabled to 3/4 status pie before reactivating AutoTrac™ by pressing the resume switch.
Edited by superfordman 8/3/2020 12:02
