ne MD | We have one. #8 got badly bent, so we used a piece of 1/2" carlon electric conduit instead. I think it is complete otherwise. Off of a 346 with a #30 ejector. We put a electric one on instead. Probably too far, but located in Rising Sun, Maryland. Just south of Lancaster County, PA. Be warned, we did not like it much because if you forgot to slide in #8 when you swing in the tongue it would get bent easily when it hit the rear of the fender or tail light on the tractor. While baling, you had to also be watchful, because when ejector was tilted it would often change the distance setting by itself, usually down for some reason. We like the electric one much better, even on a open station tractor.
Edited by mkengland 7/29/2020 14:35
