Search Forums | Classifieds (60) | Skins | Language
4710 section control on 2630
Lil' Hoss
Posted 7/22/2020 19:04 (#8389821 - in reply to #8386951)
Subject: RE: 4710 section control on 2630
NESD
Sprayer may need the Spray Controller replaced with a GEN 4 Spray Rate Controller ( Not to be confused with a Gen 4 display) with software version 5.16 or higher for Swath Control Pro or Section Control to work, you can find the software version in the Original Greenstar Display, if the version is not this or higher you may need to remove the floor mat and the floor panel to access the Spray Rate Controller to verify that it is a Gen 4, If not a Gen 4 do not try to update the software as it will damage the controller making it non functional.
Edited by Lil' Hoss 7/22/2020 19:05
