Central KS | 2015 case 470 rowtrac with a new steercommand install. Can run fine a couple rounds and then in the middle of a line with kick out with manual steering override. When this happens it will continue to kick out as soon as you engage. A new wheel encoder has been installed already. It also has the new style Ag Leader Steiger cable. I’m not sure what else it could be. It’s gotta be a CAN message on the Case side sending that to the steercommand. Not sure where else to look. Just seeing if anyone else has run into this??? Any help appreciated! | |
