Posted 7/16/2020 15:19 (#8377620 - in reply to #8374101) Subject: RE: Export varieties to pro 700
When you export out your Pro700 setup file for the combine, in the device setup manager, last tab has a list of the spatial data available to export, select the 2020 planting operation and load on to USB device. Be sure to use a USB that is 4GB or less.
Hope this helps.
