Posted 7/13/2020 19:58 (#8371936 - in reply to #8371871) Subject: RE: Valley pivot pipe gasket
Fairbury, NE (Southeast)
You need to put a set of forks uder the joint, one on each side of the flange. Unbolt the top set of bolts and remove except the bottom two, and loosen them. . Apply upward force on the joint, It will open up enough to allow the gasket to drop in with a little finagling. Not a terribly bad job.
