SE IL | I don’t think you will be happy with section control just using sf1. I would suggest at least sf2. You will need a sf2 ready receiver either 3000 or 6000. Probably should go ahead and get a 2630 rather than a 2600. You will probably be able to find a better deal on a used display that already has the auto track and section activations. The display needs a sf2 activation for the auto track if you want to go that route. The sf2 ready receiver will need a subscription to the sf2 signal. There are different length subs available. IIRC 3 months to 3 years. The 3000 will be a little less expensive up front but it’s been around for a while and I don’t know how much longer they will be supported. Several more years I expect. | |
