| With out going out and buying new nozzles I currently have Tee Jet XR flat fans and Tee Jet Turbo T Flats available. Which would be preferred. They are both flat fans and we run high pressure and 15 to 20 gallons per acre. The XR's seem to get it too fine at times running high pressure. (wondering if some is evaporating on hot days) The turbo tee's i think get a little better penetration especially with the fan at a touch of a angle. I have used both in the past and have had great results. Just wondering if one if better than the other before I start. | |
