Posted 7/11/2020 17:14 (#8367596 - in reply to #8367177) Subject: RE: JD 4720 sprayer A/C, or 7X20/30 tractors A/C question
Pilot Grove, Missouri
Low side pressure seems pretty high. If you had low air flow through the evaproator or icing up, the low side pressure would be low. It is more likely that your condensor is dirty. The newer equipment the condensors usually look clean until you hit them with a pressure washer and mud comes out. Patrick
