| Hope I can describe this in a way that makes sense.
I struggle to get my spra coupe to "pull into" the next pass when turning on the ends of fields while spraying. Is there something Ive not set up correctly or am I asking for something its not capable of? I use no subscription signal, just wass.
Fantastic going across the field just tough finding where to turn in. As it is I try to watch how many feet until next pass and start turning so I end up close. Have had the best luck pulling up to the end and backing around, using the end of the boom as a guide to get close to my starting point on my next pass.
I would appreciate any thoughts or suggestions or experience.
Thank you. | |
