Posted 7/10/2020 11:25 (#8365229 - in reply to #8365115) Subject: RE: Tyler Patriot WT won’t start.
On mine with the JD motor I had to bleed the fuel system if it sat for several days which involved cracking loose the #1 injector nut while motoring it over with the starter. I finally put an electric fuel pump in line to act as a check valve and help with starting which did help. Keeping the fuel tank full when parking it for long periods helped as well.
