just a tish NE of central ND | Go over into the passenger side, and on the dash top is a large cover that covers the fuses and relays for the truck cab and lights and wipers and ignition. TAKE a good look at all the bigger relays and maybe swap some of them out with other identical relays to see if the problem follows the relays and breakers to a different spot. Just several days ago I swapped out my headlight relays with new ones and problems with my headlights now is solved. BAD RELAYS!! Then I swapped the headlight relays with my windshield wiper (2 of them) and solved my lack of low speed windshield wiper. There is a good chance that the dash is controlled by one or several of those relays in that fuse box area. Mine are labeled into the fuse holder area what they are meant to run. |
